Willrt87
Hi I recently bought a new house with a well. Since I moved in I noticed the pump running every 10-30 seconds for like 10 seconds when running water. The water pressure was ok but when the pump would kick on the water pressure was really good. So I did a little research on checking if the tank was good.
The check valve says 30/50 on it but when i checked it the pump was kicking on at 35 and shutting down at 40. So I tried adjusting it and noticed if it was set to shut off at 50 it would just keep running if the water was on. After getting it to turn on at 30 I drained the tank and tried putting 28 psi in the tank but it would not take I could get it to 10 but it took awhile. So I figured i needed a new tank and maybe a new switch. I don't know anything about the age of the equipment or their specs.
Now my question is should i buy a new tank and switch and if so what should I be looking at?
Any help would be appreciated thanks.
Here are some pictures of what i have.
