Derek 66
Hello,
Just got our new well drilled at the cottage, please advise if setup I will describe will work correctly (spring installation).
1. 3-season cottage, no basement, no "usage" in the winter, distance to the well from pressure tank 15'
2. 4" well drilled to around 200+ feet, well production at 4+ gpm, recommended pump setting at 180'
3. not possible to install pitiless adapter below frost line - solid rock, maybe a a foot or two, but still no basement for pressure tank anyway
a. 3/4hp ecoflow EFSUB7-123 12gpm pump with 207 head & 1 1/4" outlet
b. 1 1/4" poly pipe up to the pitiless adapter (or 1" is better?)
c. halfway up 1 1/4" check valve (is it really needed?)
d. 5' before pitiless adapter drain back valve (to drain/eliminate water from above frost line in the winter) or is there a better way?
e. 1 1/4" pitiless adapter
f. 1 1/4" poly pipe up to pressure tank (or 1" is better?)
g. before tank "T" with all the stuff: air release valve to purge the air introduced by drain back valve (if needed?) + cycle stop valve (if needed?) + 1 1/4" check valve
Please let me know if I missed any info and your thoughts.
Derek
Derek
