Coloradogirl
August 2019, local well service installed: new 220 1 hp submersible pump; new QD pump controller; new fiberglass 100 gal tank and returned a few weeks later to replace 30/50 with a 40/60 pressure switch.
Within weeks (Sept. 2019) the controller shut off well and on reset found the pressure switch rapid cycling machine gun fast - pressure bouncing to 20 psi cut in to 40-45 psi cut out then 43 cut in 50 cut out. Called well installer but as it was a weekend, told them I'd limit use and they could come normal business day. He never called or showed up - illness hampered my follow through. Until May 2020, I called and informed them the short cycle was so rapid the p-switch was sparking and controller was hot to the touch that I would limit use (100 degree weather) until they came out. Was told he was busy, after 4 weeks called again and asked when??? as my trees and landscaping were dying. At 6 weeks I called a different well service that arrived 3 hours later.
The pressure switch had burn marks on lid and had to be replaced. On replacement, the short cycle continued and they emptied tank and found the pressure to be 55psi (no water from schrader valve) and they bled pressure to the 38 psi cut in and the pressure switch worked normally. At 7 weeks, the orig installer called and said he could come out. When informed I had another repair and would bill him - he was pissed.
It is about 3 weeks after repair and the system is starting to short cycle again, which I interpret as the problem is upstream from pressure switch; a faulty tank was installed or faulty pump - or both. Clearly the installer ignoring extreme short cycling put the longevity of the new pump at risk but how do I proceed on getting the system operating? I am concerned the orig. installer may have delayed to run out the warranties and have some trust issues there. The system components that were replaced had lasted for 19 years - the replacements only weeks before malfunctioning. If it were you - how would you proceed?
