Rman
Master mechanic
Hello I’ve had to have a new well drilled at my house but because the lot is small and no access to the back yard it was drilled in the front yard 10 feet from the septic. The DEP and town required a min of 140 feet of 6 inch casing and 10 inch casing to bedrock which was 80 feet. The well was drilled to 325 feet. At 275 it started to produce water at 4 gpm. At 325 it’s 4 gpm. The static level is 5 feet from grade. I’m on a mountain can’t explain why. But is my column of 320 feet in the 6 inch hole enough for a single family home 2 adults ?? If I draw 10 gpm and the well produces 4 gpm will I run out of water and how soon ? No yard irrigation just Home water stufff. Concern is when there is a house full of people on special occasions. There is a small 10 gal pressure tank on a cpv valve system. Should the pump be sized at 5 gpm or will the 10 gpm pump set at 300 feet be ok. Oh all the fixtures are low flow type. Thanks
