My wife and I are in the process of buying our first house in Northwest NJ and we just got back the NJ Private Well Test Act results. A few items exceeded the limit values and I am interested in everyone's thoughts on the matter. Topic results are as follows:
- Total Coliform, present. E.coil, absent.
- pH: 6.08
- Lead: 16 ug/l
- Iron: 48 ug/l
- Copper: 130 ug/l (this is not technically an exceedence but still a question for me)
The house was built in 1977 and has a 215ft well drill at that time. There are no current water treatment devices installed other than a sediment filter. Sample was taken at the kitchen tap, and have to assume it was taken correctly I suppose. It is a 2.5 bath house.
My questions:
1. What are the most common sources of TC? Unfortunately the test was pass/fail and did not give concentration.
2. That lead concentration exceeds the EPA action limit for first-draw test. The NJ PWTA mandates running the tap for a minimum of two minutes before sampling. How the heck is lead still this high?
3. For the same reason as above with the lead, I feel the copper result cannot be meaningfully compared to the EPA 1300 ug/l action limit. How bad is 130 from a running tap? There is definitely some green staining around fixtures.
4. Given the results, what components, or set of components, would everyone suggest for remedying the issues? Acid neutralizer? Some filter combination? UV thing? Open to all thoughts on the matter.
Thanks very much!
Matt
- pH: 6.08
- Lead: 16 ug/l
- Iron: 48 ug/l
My questions:
Thanks very much!
Matt
