Master Plumber Mark
If you do not have a checkvalve, when you open the hot line for water, it will pull from both the top and the bottom of the WH...not a good situation. Not all checkvalves will work in this instance, and their location can make a difference between success and failure.
You cannot have a check valve in the line if you wish it to naturally flow with gravity..
I know this from having to take them out of lines many times before.......
we have made this
mistake 2 times over the past 45 years... you remove the check valve and the system
corrects itself and works like a champ......
