RVBraq
Hey guys,
Love this forum, have received a lot of good advice on some plumbing issues in a home I recently bought. Been heavily researching a water softener install and after discussing with some local plumbers, I can't seem to get a straight answer on sizing/whats necessary - Hard to tell if they're trying to upsell me or if theres some legitimate concerns. I've decided I'm going to install this myself. Here's the setup I'm looking at:
1)Fleck 5600 SXT from AFWFilters - 40k Grain
2)We're a house of 3 people (with another baby on the way). Water usage is very much average. I've had hardness measurements ranging from 7 GPM to 12 GPM, depending on the test I'm using. We have 3.5 baths but only 2 are regularly used. On municipal water and were sitting at about 60 PSI after the house regulator.
3)Curveball here is that the entire house is piped in 1/2 inch after the meter -Hasn't been an issue to this point but im sure as the kids get older, it'll be a great time.
Major concerns here are flow rate and oversizing. I believe the unit I'm looking at has a peak service rate of about 12 GPM, which I assume is all 1/2 inch pipe can handle anyway. For the size, I've landed on different results..Formulas around this website put me at about 24k grain, one supplier recommended 32k and another supplier recommended I go up to 48k.
I'm thinking the 40k simply to avoid any issue with flowrates down the line - I was told there can be settings on the fleck that can maintain good efficiency despite being oversized for the needs? Would love any thoughts on this setup ad any recommendation you guys might have.
