Belled ends are better. You should be able to get sch 40 in belled ends as well.
Ok thanks. So what keeps the pressure off the pump? The CSV?
I like that answer, valveman
Do you think I should put a Cycle Sensor in ?
https://cyclestopvalves.com/collections/cycle-sensor-pump-monitors/products/cs1ph1-2hp230v
I like that answer. Actually I could run at 10 GPM for 70 minutes right? Remember it’s putting 3 GPM in while I’m taking 10 out. Ok. Thanks valveman you’ve relieved my mind. Back to diggin. Those sensors are expensive but maybe needed in this case.
That's a problem. When you add primer and glue, the pipe will fit farther into the fittings. If your pipe is not long enough before you add primer and glue, the pipe will not go all of the way. You could get leaks.Nothing is glued.
