Hi All,
I've learned a lot from this site and am hoping some of you can help me.
I have small house and am adding 6 rental cabins and am having trouble
figuring out water supply.
there is currently a 60ft well with standing water at 15ft, Grundfos 15GPM 1/2hp pump to house
with SQE CO 301 brain.
Initally was going to do second pump and systme but I'm low on funds and trying to figure
line from house.
farthest cabin is 300 ft with over all run to all 450.
can I add water booster pump from house after house system?
or a second pressure tank?
or CSV?
I'm very limited on knowledge of all this and hoping for some answers.
Cabins are studio with shower toliet sink kitchen sink on demand water heater
cabins are same elevation as house.
water line is 1" to house and to all cabins
there is 2nd pitless in well but uncertainty in size of 2nd pump and design of system
and running low on funds to implement so looking for solution for this summer.
looking at putting bootser pump
Grundfos 98562818 SCALA2 3-45 AVCBDF 1x115V 60 Hz Pressure Boosting Pump
after house????
Thanks for any input.
KSB
We put pressure valve on farthest cabin and it was 50 and went to 7 after opening up other 5. after setting cu 301 to 90 and valve showed 90 at farthest cabin it went to 10 after opening up other 5. house pressure stayed good both times.
do I need a bigger pump? would CSV with this 1/2 hp and 15 gal min work? or bigger pressure tank? currently have 2 gal pressure tank.
I'm thinking i could put a pump above the well with CSV and run above ground line to first cabin to connect to system and supply all the others and stay seperate from the house? any recommendations on pumps?
line from house.
or CSV?
after house????
KSB
