DPForumDog
Pump is not building pressure. Would a check valve on the suction side near the pump cause prime problems?
We are trying to pump pond water for irrigation. I have a foot valve in the pond and then 70 ft of 2" pipe going to the shed where I have a Red Lion 77 GPM 2 HP Self-Priming Cast Iron Sprinkler Pump w/ Brass Impeller (RL-SPRK200-BR). There is about a 5 ft rise over that 70 ft.
Originally i had the check valve on the down stream of the pressure switch but every time the pump shut off the pressure would drop below 20 lbs, and the pressure switch in the auto function shuts off and want come back on until its manually moved to start. So I changed the check valve to the suction side.
I would appreciate any ideas.
Thanks
Granny DP
DPForumDog
Thanks
Granny DP
DPForumDog
