Pistol Pete
Good day all,
I have recently installed a Grundfos 15SQ05-110-115v pump and it won't build pressure past 38 psi. which does not allow the 30/50 switch to cut out. If you isolate the pressure tank (there is a valve on it) and isolate the house so that the pump dead ends at the switch/gauge and throw the circuit breaker supplying the pump, the pressure will drop to zero after only a minute or two. I suspect the check valve on the pump is stuck open, which would account for the loss but would a stuck check valve prevent the pressure build up necessary to satisfy the switch in the first place ?
I would think the pump would run until it hit the cut out pressure, shut off, lose pressure, cut in and cycle itself to death if left as is. But it never gets past 38 psi. There is no sound of a leak at the well head (at least above the water mark) The down pipe (one piece tubing) was in good shape when it went back in but I concede a hole below the water line might account for this. Thoughts ?
The well is 136' deep
Static level is 88' from the surface or 48' of water.
121v supply
Pump draws 4.8A when running
Thanks,
Pete
121v supply
Thanks,
Pete
