I am relatively sure my pressure tank is bad, when you turn the water on the pressure gauge goes up and down rapidly and the relay kicks on, off, on, off, the entire time water is running. My problem is the pressure tank is in ground and, being buried almost 20 years ago, I am not real sure where it is. My question is, rather than digging up half my yard can I leave the faulty tank alone and simply install a new tank. Our home is different than when the well was first drilled and I have room to put a tank under the house where the pressure gauge and relay box are. The pump is submersible. My thinking is if the old tank is flooded and has no air pressure it would basically is now just a big bulge in the supply line and there should be no problem with just adding a new tank but I am not positive.
