Find where the leak is first. It may take another turn on a threaded joint. If the leak is at a barb-to hose place, another 1/4 turn on the worm gear clamps might solve that.
Or maybe there is no leak, and the problem is something else. How far down is the surface of your water below the top of the pump?
Or maybe you mean to wait until the water in the pressure tank is down. Easy enough... just open a valve and drain the water.
I don't understand about waiting until the water level is down. Turn off the pump, and go, I would think.Or would I have to wait til water level is down and take the shut off right out of the line, retape and tighten together with pipe wrench?
