hdude
New 2 HP Franklin Motor - New L20P4HS Pump - New Control Box - New CSV Valve - New Tank.
Motor Starts @ 2.85Kw(12a) - Pumping motor@ 2.45Kw (10a)- and when demand stops (CSV @1GPM) motor runs @ 1.25Kw (5a). Franklin says it should run at 1.5Kw (6-7a).
CSV is set to 55PSI @well, shows 50PSI @TANK (10 ft elev + 50 of 1 1/4 pipe) and the house pressure drops to 30-35PSI (100' of 1 1/4 pipe into 2 3/4" pipes of 30') while GeoThermal demand about 6-8GPM (bucket test through 3/4" drain line spigot). All new guages and they have been cross checked. I am using a reliable monitoring/graphing program. I have a Cycle Sensor being shipped so I can x-ref my amp draw and make sure I am not exceeding well recharge/capacity since I am not 100% sure of this. I am trying to balance Geo with other needs at reliable draw and pressure.
Not cycling - but the 10amp concerns me. Wattage seems in excess of what I'd expect and very high for new pump. Any thoughts?
