Tim Fastle
We have a 3600 sf home with an attached 700 sf Casita (or guest house) that has radiant floor and baseboard heating (so no air handler) and evaporative cooling. We are considering converting the cooling to AC and would like to see if anyone has any input into IF we should do it and HOW it might be best done.
Currently there are two MasterCool evap units on the main house and a smaller Champion evap on the Casita. The MasterCool units are down draft and each one goes into independent venting systems (1 is basically the living areas, the other is basically the 3 bedrooms). The cooling units are on a flat roof (adobe style home) and, although they are only about 15' apart, the venting systems are not connected. The Casita cooler has it's own minimal venting system.
We grew up in Albuquerque and 6 years ago moved back. I know when I was young evaporative cooling was the most common system because of cost and effectiveness. I believe now that refrigerant systems have gotten much better and more efficient and, it seems, are a superior option even in this very dry climate. Does that sound correct? It sure seems like the homes and businesses I go into that have refrigeration AC cool much better than the swamp cooler homes and businesses do.
I have called around to some HVAC professionals and it seems that each wants to do it the way that they want to do it and I am not sure if that would be the "best" way to do it so I thought I might get some input from the brighter and more experienced minds that are on this forum. It seems to me that an ideal way to handle it would be a single compressor/condenser coil unit tied to 3 air handler/evaporative coil units, one handler each located where the old evaporative coolers were (of course, each one sized for it's task). I know very little about such a conversion and don't even know if what I described above is possible. Is it and would it be the most cost effective way to design such a system? Or, would there have to be a combination AC unit/Air handler for each venting system (3) and might that even be the most cost effective way to design the system? Or is there a better way to go about it? Or, are we better of just sticking with the evaporative coolers?
My experience is that as you begin to consider something like this it's best to have an idea of what your best options might be so, as you speak to the "experts", you don't end up with what is best for them and maybe not so much for you. Any thoughts, ideas or input would be greatly appreciated! If I left something out or there are questions, please ask away.
Thanks in advance.
Thanks in advance.
