Keith Wollaver
I attached a picture below of the actual set up. The waste line comes in from the rear wall under the sink and connects to a 2" p trap that has a compression fitting at that end and connects to a tail piece that has been reduced to 1.5" with a reducer. The tailpiece is not a problem, but as you can see the dishwasher branch is out of place unless the p trap can be lowered. I have not yet found a solution at the stores. The sink is located in a peninsula counter and the waste drain runs horizontally within the wall. I considered opening the rear outside wall as it is easy access and lowering the waste line that runs into the cabinet, but I do not know if that works knowing that the waste water would then have to run up several inches to match with the original location of the waste drain inside the peninsula wall. What would you suggest? Thanks. Keith in AZ
