The white foaminess is likely air that is being purged from the system since it is just new. That should go away within the next regeneration or two.
Your capacity is set to too high. While your resin quantity totals 48K capacity, the total capacity should not normally be utilized.
Regular resin is commonly specified as 32K grains per cuft when first manufactured. As some resin will be fractured during manufacturing and during repeated regeneration over time, broken fragments will be flushed to drain so some capacity will be lost. In addition, some capacity is consumed during regeneration as regeneration of a single tank softener is performed with hard water. For those reasons, total capacity is commonly estimated as 30K /cuft.
The salt quantity required to restore 30K of capacity/cuft is 15 lbs per cuft. Your 1.5 cuft softener would then require 22.5 lbs of salt to regenerate all 45K of capacity which would equal only 2000 grains per lb of salt.
Your current BF setting of 45 minutes X 0.125 BLFC = 5.625 gallons. As each gallon will dissolve 3 lbs salt, your current salt setting is 16.875 lbs which is not enough to restore all 45K of capacity.
Salt efficiency can be drastically improved by setting 'C 'as a lower number and reducing the salt setting (BF) accordingly. With your softener, if you set 'C' as 30, your usable capacity between regeneration will be 30K, but to restore that capacity will only require 9 lbs of salt (6 lbs/cuft) which is an efficient 3,333 grains per lb. As usable capacity is set higher, salt efficiency will decrease but the interval between regeneration will be longer. For instance, 36K of capacity would require 12 lbs (8 lbs/cuft) = 3000 grains/lb whereas 40.5K capacity would require 15 lbs (10 lbs/cuft) = 2700 grains/lb.
You experienced salty water after regeneration as there was too much water in the brine tank for the BD that is set. That water was likely added manually by you since the unit was only just installed. Since the water was added manually, that does not indicate that your water will continue to be salty after a properly set fully automated regen cycle occurs.
BD is actually 2 processes in one setting. Brine is initially drawn from the brine tank until the brine level reaches the air check valve which will then close, preventing air from being drawn into the brine line. Water will continue to slowly flow through the resin during the remaining time, thereby rinsing away the brine that is within the resin.
The time required to draw brine from the brine tank should be no more than 1/4 of the total BD setting. That is 15 minutes for a 60 minute BD setting common for most, depending on the injector that was installed. As it initially took 30 minutes to draw brine, not enough time remained to rinse away all of the brine from within the resin tank.
Suggest setting 'C' as 30 and 'BF' as 24 minutes (.125 X 24 = 3 gallons X 3 = 9 lbs of salt)
Currently, your brine tank will contain almost 6 gallons of water so you may again experience some salty water after your next regeneration. With the settings as suggested, I expect that should not occur again.
H - currently set as 10 grains. How did you determine that setting?
RC - reserve currently set as 150 gallons. Commonly calculated at 60 gals per person.
