New Infloor Radiant Heating System - Questions
Discussion in 'HVAC Heating & Cooling' started by tuffcalc, Jan 10, 2018.
  1. tuffcalc
    tuffcalc New Member
    Jan 10, 2018
    Ontario
    Hi everyone,
    New around here. Hoping someone can help a newbie out.
    I'm building a new home (basement, ground level and upstairs). I'm having infloor radiant heating installed on each floor. The HVAC company has designed a system with these specs.
    1. 17 zones
    2. 17 Tekmar 561 thermostats
    3. 3 Tekmar 306V Zone Valve Controls
    4. 3 Groundfos Alpha2 circulators (one circulator per floor)
    5. 1 Lochinvar Knight boiler
    My question is this - if the Tekmar 306v can only control one circulator when a zone calls for heat, how are the other circulators wired up so they also turn on when the respective zones they serve call for heat?
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    With 17 mostly low-thermal mass zones and NO BUFFER TANK (??), you're in danger of short-cycling the boiler silly on zone calls, into low as-used efficiency and an early grave. If it has a thermally massive hydraulic separator (like a Boiler Buddy or similar it might be OK, but any system that it micro-zoned to the nth (in this case 17th) degree this is an issue that has to be designed-for.
    You have three Tekmar 306Vs, and three pumps, one per zone controller. Each 306V turns on it's dedicated pump whenever any one of it's zones are calling for heat. If the Alpha2s are programmed for constant pressure or auto-adapt it will bump up the power to maintain proper flow when more than one zone on that controller is calling for heat.
  4. tuffcalc
    tuffcalc New Member
    Jan 10, 2018
    Ontario
    Hi Dana,
    Yes I'm aware there is risk for short-cycling due to the many zones. We are not installing a buffer tank. Here is the thought process:
    1. We've chosen the second smallest Lochinvar knight boiler (WHN086) that has a 10:1 turndown ratio, so on the lowest fire it will put out 8,500btu.
    2. If there is a heat demand more than one zone should be calling. Some of the zones are also very large (e.g., 1000sq ft. or more).
    3. The RoomResponse function on the Tekmar 306 will tell the boiler what setpoint to fire at. In low demand situations the setpoint should be very low (less than 100f?) which would force longer run times. Couple this with, ideally, more than one zone calling.
    On paper it should work and keep the boiler from cycling. We will see how it works out in practice.
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    The min fire INPUT of the WHN086 is 8500BTU/hr.
    It's min-fire output in condensing mode is ~8000 BTU/hr.
    That definitely helps, but some of those zones are likely to have incredibly little thermal mass. Even a 5 gallon electric water heater (unpowered) employed as the hydraulic separator would be able to tame it, should it short cycle on you.
  6. jadnashua
    While you can put multiple loops on one controller, depending on the tubing size utilized, you generally don't want any single loop to be more than about 200' long.
Similar Threads: Infloor Radiant
HVAC Heating & Cooling Use of Reflectic for infloor radiant heat Dec 7, 2008
HVAC Heating & Cooling Designing a new hydronic system for my home, cast iron radiators and radiant floor? May 13, 2018
HVAC Heating & Cooling Adding radiant heat to existing hydronic baseboard heating Apr 16, 2018
HVAC Heating & Cooling Understanding hydronic radiant heat, and a potential retrofit? Mar 8, 2018
HVAC Heating & Cooling Question on hose material for hydronic radiant heat Mar 5, 2018
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
