New house sewer backing up
dthomas
Quebec
Hi - 1st time posting here!
I replaced ~33' of 3" house sewer ABS DWV in a friend's house back in September (inside of the house - suspended under the 1st floor). He has had repeated sewage back-up in this drain over the past three years. Once sewage exited his vent stack (~six years ago).
I installed a 1/4" pitch per foot on the new 3" drain, ran water through it for 1 hour, and it ran clear & effectively drained. My friend checked the drain about three weeks ago and there is a small quantity of sewage back up from the horizontal clean out.
A plumber drain-scoped the street-side/municipal drain two years ago and did not find any blockage/roots/etc. There is no backflow valve on the DWV.
Any insight/opinion/solutions would be greatly appreciated.
THX.
FYI: The drain drops about 3-1/2' to exit through the wall to the street DWV; the street DWV is about 3' above the basement floor. There is a Y connection from a sewage sump pit connected about 18" above the street DWV and an air cheater/cheater vent from the sump pit.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
by "cheater vent" you mean an AAV (air admittance valve) on the sewer pump. I can tell you definitively that the 2" vent needs to be thru to the roof. AAV Can't be used on a sewer ejector system.
A 1/4" slope on the main drain, supported at 4 ft. intervals rigidly as required should drain perfectly. I will leave to others to comment on the execution of horizontal wet venting.
What is "this drain"?
Out onto the roof?
dthomas
Quebec
Out onto the roof?
(1) "What is "this drain" " = the 33' horizontal drain under the main floor of the bunlgalow.
(2) Yes - sewage backed up the full length of the 33' drain and spouted out of the 3" vent/stack onto the roof. He had this cleaned out and the plumber scoped the whole drain length. Apparently no blockage was found. There was a slight reverse "sag" in the original cast-iron 3" pipe, but that's what I swapped out and supposedly corrected.
dthomas
Quebec
THX. I'll take this into consideration in this mystery.
2A. What kept water from spewing out of the WC? Could it be that the vent that spouted water to the roof was not the 4-inch cast iron vent stack, but some other vent that was downstream of a backwater/check valve that you don't know about?
2B. Is this diagram just representing the basement plumbing? There is no shower or tub shown, so that cannot represent the whole house.
dthomas
Quebec
2A. Don't have an answer for this first Q. It was the 4" cast iron vent that spouted the sewage on the roof; this is the only vent servicing the entire drain system of the home.
2b. The 3-d diagram illustrates (sorry - I didn't do well in art class :() the entire drain system of the house - it is a bungalow. The shower/tub drain is represented by the 2" T in the centre of the diagram (just after the 3" WC notation).
Again - sorry for the poor artwork & THX for your input.
It takes more than a Wrongly installed aav on the ejector pit. but get rid of thayt aav that wont stop up the upstream there is still a wye there for all the waste to travel the only way gravity allows youve got a stoppage , roots , toys , dislodged sewer piping backwater valve sticking something between the house and the street
