Paul Marsh
Hey guys, recently bought a house about a year ago. Noticed there was a well pump in the garage for irrigation. Haven't used the irrigation yet as we plan to overhaul the backyard and redo the sprinklers. There is no bladder tank or pressure switch on the pump, it is turned on automatically via a relay with the sprinkler timer box on the wall. I have a 3/4 inch ball valve hose bib on the discharge pipe and when testing the pump it takes about 2 - 3 minutes for it to start pumping water out the discharge pipe. It is a 1 HP pump, not sure how deep the well is. I was concerned the pump wasn't staying primed and that the check valve on the suction line was bad so I replaced it but upon further inspection, the original check valve indeed functioned as intended. Once water starts flowing, it runs about 45 - 50 PSI at 20 GPM. My only concern is if the check valve is functioning properly and keeping the pump primed, is it still normal for it to take a couple minutes for water to flow? Does it actually take that long to siphon water depending on the depth of the well? I just don't want to burn the pump out. Thanks in advance!
