Chris Joseph
I could not find a Lab60 kit as some suggested but did a KAR90. This test came in very different from the one done by the well Driller when I was looking to install a system. The drillers report was 10gpg Hardness, 2PPM Iron and PH of 6.5.
The Kar Report was 13.1GPG Hardness, Iron was ONLY .05 mg/L (I believe this also equals PPM) and the PH was up to 6.7.
Both tests were taken right from the well, not thru any softeners...
1. I had a GE Conical Whole House filter inline, The type that uses an approx 8" by 4" tube to filter sediment. This filter would be caked with RED SLIME and show sediment at the bottom of the housing.
How does this happen if my Iron (according to KAR) is only .05 mg/L? Would some other combination of minerals/Hardness cause this? Or is .05 mg/L still capable of causing this effect?
2. Should I retest from KAR? Is there still a KAR 60?
Water test attached....
Thanks.
Chris
Thanks.
Chris
