What are ideal setting for hard water value 7 (120 ppm). Hardware periodically with proper regeneration.
Here are the details of my system:
City water with sediment and carbon filter before softener,
4 people in the house.
Hardness test: 120 ppm - 7 gpg
5600sxt
1.5 cu. ft resin
.5gpm / 1.5lb salt/min blfc
Turbine flow meter
Any suggestions on setup would be helpful. Thanks !
Current settings
BLFC: .50 GPM 1.5LB
DF: GAL
VT: dF lb
CT: Fd
NT: 1
C: 36x1000
H: 7 (Water hardness measured - 120 ppm)
RS: SF
SF: 10
DO: 14
RT: 2:00
BW: 10
BD: 60
RR: 10
BF: 10
FM = t0.7 I believe this is default.
Also noticed softener tank & inlet , outlet pipe freeze how to fix that too ?
Installed in garage
5600sxt
1.5 cu. ft resin
Turbine flow meter
Current settings
BLFC: .50 GPM 1.5LB
DF: GAL
VT: dF lb
CT: Fd
NT: 1
C: 36x1000
RS: SF
SF: 10
DO: 14
RT: 2:00
BW: 10
BD: 60
RR: 10
BF: 10
Installed in garage
