Seth B Rosenberger
Hi, I am hoping for some advice to help me fix my issue and more importantly, understand what I did wrong.
I have a new dual vanity that I decided to plumb with two traps. I thought it would be better than one but obviously with my setup, I was mistaken. If I run either sink alone, they work flawlessly. If I run both together, after a few seconds they start draining slowly and backing up. What went wrong and is my setup salvageable or should I just use one outlet and tie them together under the vanity itself while plugging the other outlet.
Please see attached pictures for my setup. I did this a few months ago so I'm 99 percent sure I am set up like the first picture but there is a small chance it is like the second.
https://photos.app.goo.gl/TtUcVTv1biFDCJ9NA
https://photos.app.goo.gl/HgJPMBeGAGY3Gbtq5
As a final note, I tried adding AAVs just to see if that solved my problem. I thought maybe I had created negative pressure that could be relieved. They did not solve the issue but obviously, I couldn't get them above the flood rim since I just threw them under the vanity itself as a test.
Thanks in advance
Thanks in advance
