First time posting here after spending hours reading and learning from all of you. Thanks!
Recently remodeled my shower with
Delta R10000-unbx valve & Delta T14294-CZ (single handle) trim kit. Since installation, flushing system and checking for leaks, I’ve closed it up & finished including shower glass. Dove into my first shower to find the water lukewarm at best. I removed the handle and adjusted the hot water guard to increase handle’s full range of motion. Still no change. In fact, now, when I move handle range of motion past the former full hot (actual lukewarm) handle position, the showe water is full cold.
After researching and reading, I called Delta to troubleshoot with them. I most recently replaced the cartidge, still no hot water.
I have two sinks & a tub in the same bathroom that all have very hot water.
I ran CPVC between copper supply lines & the valve threads, joined by shark bite couplings and elbows.
The delta rep was quick to tell me that I couldn’t use Pex due to the inside diameter limiting the flow. After reading through the installation instructions again, I confirmed that CPVC was accepted.
All the plumbing is in an interior wall that backs up to a closet.
Any ideas are welcome and I appreciate all your help in advance.
