I installed a new Delta Multichoice valve with a 3 way diverter in my shower. Model T27867. (all copper 1/2 inch plumbing connections).
3 way diverter is set up fo a rain shower and a hand shower mounted on an adjustable bar.
This model has separate temperature and pressure controls.
Only on one setting : cold water with first outlet selected, do I get a humming vibrating noise.
This happens only at low pressure. Once you open the pressure valve fully the sound stops. If you leave it humming at low pressure it also stops when you simple push on the diverter valve or change the diverter position even slightly.
Adjusting the cold water ball valve doesn't do anything.
My first thought is to disassemble the valve and reinstall it (perhaps something isn't sitting right in the valve?)
Before I do so does anyone have any suggestions?
Best photo I've got attached. Of plumbing work.
Thanks in advance.
Oliver
Thanks in advance.
Oliver
