eyeglow,
What is the goal of your plan? If it is just for fun, I can appreciate that. Is it something you want to use for plan check to get permit? Are you planning to build (or just plumb) the house, or are you going to be hiring a contractor(s). The amount of detail on the plan can vary.
Anyway, since you are in California, the code is based on the UPC. I agree that you should get a book; a picture is sometimes worth a thousand words. You may be able use wet venting in the bathroom (you run the tub and lav drain into a vertical toilet vent). But, there are different requirements for the lengths of the pipe between the trap and the vent. There is a chapter in the UPC on drainage, another chapter on venting, and yet another chapter on traps. Eventhough much of the code will not apply to your house, there are many things to consider. For instance, the area of you vents added together need to be at least as big as the area of the drain leaving the building.
Venting under the kitchen window may not be a problem. But, you need to know what your area allows for drilling studs. We do not know if you have 2x4 walls or 2x6 walls. It could be a problem if problem if you have 2x4 studs and need to go through more than 2 adjacent studs. Also, your plan does not have any clean-outs.
If you have a plumber doing the project, he will know what to do. You do not need every detail on the drawing. The plumber will have ways that he likes to do things. There are many ways to run drains and vents. But you might want to talk to him early to see if there are things in the framing that could be changed to make life easier. If you are doing the work yourself, you will want a lot of detail.
Here are a couple links that may be helpful
This one is information sheets for the city of L.A. There isn't much for plumbing, but there is a Type V sheet that would help you with the general stucture. There is another sheet on notching and drilling that can be helpful. You may check and see if your buliding dept. has similar information because it may be slightly different.
http://www.lacity.org/LADBS/faq/info_bulletins.htm#ib3
Here is some helpful information on plumbing requirements, but it may be out of date
