New build; seeking advice on plumbing design; floor plans attached
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by CPM10V, Jun 29, 2017.
  1. CPM10V
    CPM10V New Member
    Jun 29, 2017
    Phoenix, AZ
    I'm in the design stage of a new home in the Phoenix, AZ area (slab, 2 stories, Eljen septic). It will be plumbed with PEX but I'm not sure on what method to use (home run, submanifold, trunk/branch, etc.) or diameters. The water heater (style TBD) would be located (as of now) in the garage area w/ the other mechanicals. I'd also like to have some kind of hot water return for master bath and kitchen.
    If you were to spec the system at the design stage to incorporate "best practices" what would it look like, considering the Phoenix climate?
  2. Stuff
    Stuff Well-Known Member
    Mar 7, 2013
    Pennsylvania
    What does your plumber say? Lots of times the homeowner specifies the nuts and bolts but the builder does his own thing. If going in concrete slab then really important to talk.
    Also - consider making the toilet room door swing out.
  4. CPM10V
    CPM10V New Member
    Jun 29, 2017
    Phoenix, AZ
    Thanks for the feedback, and good idea re: door. No plumber is involved yet, I was hoping to come up w/ some overall design parameters to have ready when we met.
  5. hj
    hj Master Plumber
    The "design parameters" are the blueprints and locations of the sewer and water connections. HE will go from there with HIS design. If the door swings outward, it will ALWAYS be in the way of anyone using the "hallway", unless it is always closed or opened 180 degrees against the wall, which it will seldom be.
  6. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Suppose you put the hinge on the left side of the drawing so that the door swings against the closet... It could be in the way too, but maybe that would be a lesser problem.
Similar Threads: build seeking
Plumbing Forum, Professional & DIY Advice Sanigrind pump system for outbuilding? Aug 14, 2021
Plumbing Forum, Professional & DIY Advice How thick should I build a section of wall to hold shower and laundry plumbing? Aug 3, 2021
Plumbing Forum, Professional & DIY Advice Water Heater for Building Heat and Hot Water? Jun 24, 2021
Plumbing Forum, Professional & DIY Advice Building a shower: Convert from 3/4" to 1/2"? Jun 11, 2021
Plumbing Forum, Professional & DIY Advice Warning Rebuilding Watts water pressure regulator May 14, 2021
