Hi-
Hope someone can help. This is the 2nd bosch dishwasher I have owned that is making a squeel "erp" sound almost like a "seal barking" noise after the drain motor stops. Noise is coming from the diswaher.
The dishwasher is connected to its own drain on a stand pipe. The noise only happens after the drain pump stops. This 2nd bosch is brand new and it makes the noise, so I figure there is something in our plumbing set-up causing this. I have used another brand of DW for a while and it did not make this noise-only the bosch does this. Also, I can reproduce this sound if I move the drain hose up high then move it lower.
Please see the attached .jpg for our set-up.
You will see in the photo that there is a vent cap on top of the stand-pipe-I have also tried to remove this so there is more air flow behind the water>still makes the squeel.
Can someone please verify that this is a correct plumbing setup for a dishwasher.
thanks.
thanks.
