James Feger
Hello all,
I have been reading through the forums, the IRC, and the IPC. I am now adequately mixed up and looking for some sanity. . I am adding a new rough-in for a bathroom (Lav, WC, Shower) in my basement. I am going to tie into an existing 3" main off of a stack that heads to the street. My main question is related to proper venting, and what, if any, the venting provided by the 3" stack provides. Originally I was thinking I had to vent each fixture, then I read about DFU's, and wet-venting. I believe I am down to two options:
1. The 3" stack that heads up from the basement, through the 1st and 2nd floor, and out the roof provide the venting I need. (I hope, but I am sure I am missing something)
2. I can wet-vent off of the lav with an AAV into the unfinished side of the wall and that provides proper venting for the lav, the WC, and the shower. I understand the floor drain doesnt need a dedicated vent if its to be used for overflow/spill and not a dedicated true drain.
After the venting discussion, I also want to know if the lav must drop below slab as the diagram shows or if I can run the waste pipe horizontal in the wall and then 90 down to the 3" below slab. I ask because I have already jacked out the floor over the 3" line, and was hopeful I was close to done with that part of the work.
