I see another thread by Althea Later with similar questions but my equipment is slightly different so thought I would start a new thread.
Well water tested for the first time found pH 5.5. Hardness 24 mg/L. Nothing else exciting in the test result.
Purchased and installed a Fleck 5600 SXT, a pressure tank, D tube, gravel, calcite, and Flomag. Plumbed in the system, put D tube in tank, add 12 lbs gravel, add calcite/Flomag mix. Based on what I was reading I decided to go with a small amount of Flomag so the initial fill was 100 lbs calcite with about 7 or 8 lbs of Flomag mixed in (using 5 gallon bucket I poured in 12.5 lbs calcite then 1 lbs Flomag, stir to mix, then pour in the tank, repeat). My thinking was my pH would be better than 5.5 and over time I could adjust the Flomag to zero in on a pH of 7.
Ran about 100 gallons through the new system and tested the pH with a $20 pH meter from Amazon. I measure pH at 6.6 so I'm very happy. Next day I measure pH at 8.5 (first thing in the morning, no water has been used in hours). Not happy. I check the pH meter against calibration solutions it came with and with distilled vinegar and bottled water. I am convinced the pH meter works but is only accurate to maybe 0.5 pH. Day 2 with the new system I run the faucet for about a minute and check pH, now 9.0. Day 3 I get 9.5. Very unhappy, I am further from pH 7 than when I started worrying and buying the acid neutralizer.
I did a backflush and Rapid Rinse. after that I measure pH of 6.8. I'm happy.
Next day is today and woke up, ran the kitchen faucet a few minutes and tested pH. I get 9.7. Then I run the faucet for 10 minutes while flushing toilets and running the shower to get a lot of flow and test again, now I measure 10.1 in the kitchen. I am rapidly approaching the pH of ammonia. I leave everything running for another 10 minutes and now in the kitchen and 2 bathroom faucets I measure pH around 7.2.
I rechecked the meter today after these readings, it is to my best guess accurate to within pH of +/- 0.5.
My Qs:
1) Why is pH so high? Calcite should not dissolve once pH gets close to 7 so is self limiting from my limited understanding.
2) I want to take a water sample to a lab to confirm pH and to find out how much I have increased the hardness. My pH meter varied today from 10.1 to 7.0 depending on which faucet and how long the water had been running. So which sample do I take to the lab?? My kitchen faucet at 10.1 pH or my kitchen faucet at 7.0??
3) Is Flomag the same thing as Corosex? Maybe I overshot the pH because the Flomag gives up Hydrogen faster/easier than calcite or corosex?
My Qs:
