DYI13
Back in October 2016, I vacuumed out the calcite from my 14 year old Kenmore Acid Neutralizer ( 625.348241) and refilled it with a magnesium oxide/calcite mineral (Master's NS mix) due to low PH (untreated was around 5.5). That did the trick, brought the PH to lab-tested 7.2. Now, 7 months later, I checked the mineral level and, much to my surprise, it is unchanged from 7 months ago. Used my test strips, and it looks like my untreated water is around 5.5-6 and treated is definitely better, right around 7, so it appears to be working fine.
Is it possible for NS mix to have a bridge? Is it possible that very little NS mix is being used? My neutralizer backwashes 3 times per week.
I am paranoid about the PH level because I also have an indirect water tank, which had to be replaced last year after only one year of use. The sacrificial anode was completely eaten away and the domestic hot water coil had at least one pinhole leak. It almost voided my warranty.
Thank you for reading, and please let me know any action you feel I should take.
