Hello all,
Long time lurker, first time poster.
We have a well system that will be our primary water source once we get the water treated (house already had well and municipal source installed with an air-gapped bypass so for now we are on municipal). The water has dissolved iron (clear at first then develops a red tint over time) and only a slight smell.
I contacted the original well installer and they provided these details:
Pump: Goulds 2 wire 1/2hp 7LS05(422C) 7GPM pump 220v
Well & casing: Capable of 6GPM, 142ft total, 130ft to pump, 101ft galvanized casing, Static level 70ft. (115+130, 245 head pressure) <(not exactly sure what this last bit of info means)
Installed in crawlspace, there is a medium sized pressure tank and twist2clean in-line filter after tank. House is on septic.
Point of Use undersink RO system in kitchen
Comprehensive water test revealed these levels:
Calcium 24.5 mg/L
*Iron 4.31 mg/L
Magnesium 24.5
*Manganese 0.111 mg/L
Lead 0.004 mg/L
Potassium 4.4 mg/L
Sodium 3.7 mg/L
Strontium 0.4 mg/L
Sulfur 1.0 mg/L
*Zinc 6.49 mg/L
Alkalinity 86 mg/L
Bicarbonate 85 mg/L
Carbonate 1.15 mg/L
Chloride 4.8 mg/L
*Hardness 162 mg/L (9.5 gpg)
PH 8.2
Silica 8.1 mg/L
TDS 132 mg/L
Turbidity 48.2
Methylene Chloride 6.2 ug/L
Trihalomethanes 7.3 ug/L
*indicates areas I would like to address (unless someone else identifies another area that should be addressed)
I suspect the previous owners treated the well before capping it off as it appears there are some bleach bi-products here that may dissipate over time (I could be way off on this, any advice is appreciated)
Our goal is to treat water for whole house use and exclude outside spigots. Ideally we do not want to use a softener due to excessive salt drain into septic, equip being installed in hard to access crawlspace and continuous purchasing of consumables, maintenance upkeep of softeners, and excessive wear on our water heater anode.
We would like a very low or no maintenance method of treating the water if possible, preferably a system that can be paused/resumed for long periods of time without issue if the house is switched over to municipal for any reason.
With the enormous amount of conflicting info out there, I am thankful for the pros on sites like these to help alleviate my lack of experience in these matters
Calcium 24.5 mg/L
*Iron 4.31 mg/L
Magnesium 24.5
Lead 0.004 mg/L
Potassium 4.4 mg/L
Sodium 3.7 mg/L
Strontium 0.4 mg/L
Sulfur 1.0 mg/L
*Zinc 6.49 mg/L
Alkalinity 86 mg/L
Bicarbonate 85 mg/L
Carbonate 1.15 mg/L
Chloride 4.8 mg/L
PH 8.2
Silica 8.1 mg/L
TDS 132 mg/L
Turbidity 48.2
