Da Arsonist
Hello firs time poster but I could really use some help. I have a 2011 reliance 603Lort 201 model propane powered water heater. I have not had any issues beside the igniter not working well, anyways we recently had a freeze and wile I was working on some plumbing I turned of the propane to the water heater and had to pull out the burner to reignite the pilot. In doing this I bent the smaller propane tube cracking it and causing a propane leak. At the hardware store they only had the full bottom replacement with new pilot and igniter I decided to buy as I figured would fix my igniter problem. Once removing I realized my control did not have the prongs to plug in the wires. I then removed my thermo control to have a better look. By mistake I tore some wires that appeared to be sautered on to the thermo. No I’m screwed n trying to figure out what to do. I cannot find this model anywhere online or get any replacement parts. I’m wondering if I buy a newer Honeywell thermo control would it work with the water heater. The only difference I can tell is the part that goes into the water heater is shorter than the one it has on it. Please help me out.
thanks
thanks
