Need Help with wiring Mr Cool universal Heat pump
Jimmyhead5
Hello,
Hello, I'm looking to purchase a Mr cool universal heat pump 3 ton model:
MDUO18024036
and Mrcool cased a-coil model: MDUCC15024036 with Mrcool no-vac lines. My issue is I need wiring infomation on how to wire the heat pump and ecobee3 lite thermostat to my original air handler ( Bryant 355av042080 with propane back-up heat) with the following connections available: w2,y1,dhum,g,com24v,w/w1,y/y2,r. Any help will be greatly appreciated. Thank you
Fitter30
Peace valley missouri
Jimmyhead5
Users manual page 31 lower left. Page 25 set up with conventional heat and hp. Can't run a hp with gas heat together with evap coil after the furnace. Gas heat w2. In stat setup o/b in ac if heat comes on when in cooling change setup to the other letter. Hp the reversing valve energizes in heat.
The heat pump does not have a W1 terminal ( the terminal are Y,B,D,R,C,and G) what are my options?
Fitter30
Every book I've looked at has standard wiring. Page 31
Page 14
