Need help with shower trap
Discussion in 'Shower & Bathtub Forum & Blog' started by MikeLDIY, Aug 8, 2020.
  1. MikeLDIY
    MikeLDIY New Member
    Aug 8, 2020
    Tallahassee Florida
    Hello everyone, I am new to the forum. I have read it for years, but never posted. I am remodeling my bathroom which had a bath fitter "shower unit" installed over a partially demolished previous shower. Supply and drain lines were altered when the work was done, maybe there was a leak in the slab or something. However I am now wanting to relocate the drain back closer to the center, to get a more even slope each direction as well as I think it looks better centered. In the attached photos, the first shows my existing configuration, however those copper supply lines run over the drain line practically touching, so I can't quite cut the drain line and glue my ptrap far enough back. Is it acceptable to use the 2 45s above the trap to get those extra 3 inches further as pictured in second photo? That is just a mock up, so I can alter it if I need to.
  2. Terry
    Aug 17, 2004
    You can 45 the vertical, or silver solder joints on the copper below slab. Not a homeowner job, but some plumbers are capable of it. Certainly not all.
  4. MikeLDIY
    MikeLDIY New Member
    Aug 8, 2020
    Tallahassee Florida
    Thank you so much for your reply!
    So you are saying that it is okay to use the two 45s in the configuration shown?
    By soldering joints you mean moving/reconfiguring copper to accommodate cutting drain pipe further back?
    I think the PVC option would be the easiest for me to do if its correct/accepted practice to use the 45s in this manner.
Similar Threads: Need help
Shower & Bathtub Forum & Blog Need Help With New Tub Install Creaking Around Drain Sep 17, 2020
Shower & Bathtub Forum & Blog Need help identifying 1950s Kohler shower faucet Aug 29, 2020
Shower & Bathtub Forum & Blog Pfister, Need Help Identifying Shower Valve Stems Jul 5, 2020
Shower & Bathtub Forum & Blog Pfister, Need help identifying roman tub faucet Jun 19, 2020
Shower & Bathtub Forum & Blog Need help identifying ceramic stem May 24, 2020
