The 1.25" p trap under my bathroom sink corroded and leaked all over. Being the capable, well-adjusted, smart individual that i am, i popped over to Menards for a PVC p trap kit and thought i would be a hero in 15 minutes or less.
Fast forward 24 hours, and I'm still trying to figure out what pieces are called... When i tried connecting the 2nd pipe to the threaded end of the cast iron drain with the included PVC washer and nut, it get shredded immediately, and the PVC section is still loose. This is after i used WD40 to try and clean out the rust from the threads.
Can someone give me an overview of what parts I need for this? Will PVC work with the cast iron? And i don't believe i should use pipe dope or tape, right? THANK YOU!
