wwhitney
You need to measure flow rate and pressure simultaneously. Your baseline is static pressure with zero flow.
Cheers, Wayne
Cheers, Wayne
How would I do that? I took a pressure reading with nothing on and then with a couple different fixtures running. ThanksYou need to measure flow rate and pressure simultaneously. Your baseline is static pressure with zero flow.
Cheers, Wayne
That could be time of day related, as you get into the busier evening hours.Ok, I think the first base pressure reading was a fluke, because I’ve tried it again several times and only gotten around 40psi.
When you turn on one fixture, put a bucket underneath the fixture with a 1 gallon mark on it, and time how long it takes to fill up 1 gallon. E.g. 20 seconds = 3 gpm.How would I do that? I took a pressure reading with nothing on and then with a couple different fixtures running. Thanks
saleenmav has 1.5” HDPE pipe from the meter to the house.saleenmav, well your coming back with good important info! and 40 psi or 45 is not a bad reading its a fair amount. I dont quite see why a 1 1/2 meter on a 3/4 feed would be that much better than a 3/4 inch , however bigger is always better. 3/4 feed is lame though on rural property with 1/4 mile runs.
I think the water pressure at the outside hose spigot at the house stays up at about 40 during the worst symptoms.I was thinking more like an open 3/4 pipe at where the main enters house if only a few gpms come through then there is obviously a problem
Well, it's hard to tell from the presentation of the data (a pressure gauge with a max scale of 60 psi would give better resolution), but I gather the "dog bath" draws almost 4 gpm and causes a pressure drop of around 4 psi, while the "kitchen sink" draws about 1.2 gpm and causes an additional pressure drop of around 2 psi. Those pressure drops seem a bit higher than expected, but not enough to explain the complaints.I think the water pressure at the outside hose spigot at the house stays up at about 40 during the worst symptoms.
I think observations should include whether cold or hot or both was being drawn.A very interesting test that is somewhat more involved would be to insert a tee with pressure gauge between the faucet supply stop and the faucet supply line. Comparing the pressure drop during flow there to the pressure drop during flow at the hose bibb would indicate if there is any internal house piping issue.
https://www.homedepot.com/p/Water-Source-Water-Test-Pressure-Gauge-WSPGH100/308724108 would be an improvement.Well, it's hard to tell from the presentation of the data (a pressure gauge with a max scale of 60 psi would give better resolution)
That chart is labeled "minimum allowable flow rate". For a 2.0 gpm showerhead, it's 1.5 gpm at both 80 psi and 40 psi. But any showerhead is going to have at least as much flow at 80 psi as it has at 40 psi.Also, I found a document from EPA that explains showerhead output. On pg 3 has a chart of pressure and flow ratings that showerheads are supposed to meet and indicates no difference in output from 80 to 40p
https://www.epa.gov/sites/productio...ws-products-support-statement-showerheads.pdf
Videos can only be linked. Once the link is established the video will be nested.Edit: looks like I can’t upload video. I’ll try to stick them on YouTube or something and add a link.
3/4 feed to the 1 1/2 meter then 1 1/2 rest of way to house. OP was complaining like it was not his fault so why not figure out if he is getting water at a decent rate at the meter to begin with. I guess we are all looking at it a little diferantlysaleenmav has 1.5” HDPE pipe from the meter to the house.
