I run off well water and is very yellow still,
Yellow is probably the tannins, and I don't know about that. Is the 5600SXT first in line?
If the Econominder is the softener, here is what I am thinking--
ECONOMINDER System info
salt lb/cuft = 8.0 ; A choice ( efficiency vs capacity)
cubic ft resin = 2.5 ; Same as (nominal grains/32,000)
Raw hardness = 11.0 ; including iron etc
Comp factor = 1.07 ; High-hardness compensation factor
H compensated = 11.8 ; Hardness grains after comp factor
Capacity of resin = 60.0 ; capacity in 1000 grains
Gallons total = 5096.6 ; Gallons without considering reserve
Estimated gal/day = 360.0 ; 60 gal per person typical calc
Est days/regen = 14.2 ; presuming days each use reserve capacity
ECONOMINDER Settings:
LBS.OF SALT = 20.0 ; Brine cam in back, pounds of salt
White Dot gal x1000 = 4.74 ; Pull clear wheel to set
*** Note that I am assumin
g that your wheel is in x1000... Your white dot is currently at about 5.66, it looks to me.
