Bannerman
The standard residential BLFC (brine line flow control) restrictors are rated at 0.125, 0.25, 0.5 & 1.0 gpm.
The BLFC appears like a rubber washer with a specific size tapered hole in the centre and with a flow rate number moulded into it. The taper allows the flow rate to remain consistent over a wide pressure range. The restrictor placement will allow a higher flow rate past when brine is being drawn compared to the specified flow rate when water is flowing in the opposite direction when filling the brine tank.
