Need help with compatibility of old Delta Shower Faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by AdamCP, Feb 8, 2021.
  1. AdamCP
    AdamCP New Member
    Feb 8, 2021
    Michigan
    My home was built in 1994 and the shower/tub trim kit I'd like to replace is original (see pic). I thought that it was a 1500 series so I bought RP32104 cartridge from Delta and a 1700 series trim kit T17430-SS. However, when I went to take the old unit apart I noticed the trim ring screw holes were both at the bottom at roughly 5 and 7 o clock as opposed to 1 and 7 o clock on the new one. My question is can I find a compatible trim ring with the screw holes at the bottom and use the rest of what I bought, or is everything incompatible with the rough-in that's currently installed?
    [​IMG]
  2. Marlinman
    Marlinman In the Trades
    Dec 13, 2018
    Jacksonville Florida
    Remove your trim and look at the valve body. I still have some 1500 series valves and they will accept the screws at 5 and 7 and 8 and 2 as well.
  4. AdamCP
    AdamCP New Member
    Feb 8, 2021
    Michigan
    You were right. There were 4 screw holes in the rough in, so the escutcheon fit just fine. However, the old assembly had a threaded bonnet nut and the replacement kit I bought just has an unthreaded sleeve. So I've had to Frankenstein it for now until I can figure out what piece to get to make everything stay in place tightly. If I slide this unthreaded sleeve over it fits just fine, but it doesn't hold the cartridge in nice and tight. Let me know if you have any ideas.
    [​IMG]
    [​IMG]
    [​IMG]
  5. Marlinman
    Dec 13, 2018
  6. JohnE316
    JohnE316 New Member
    Jun 21, 2020
    Illinois
    I just did the same replacement.... The o-ring that @Marlinman has in his photo goes on. It makes for a tight fit though. I used some liquid soap to lubricate it so I could push it on over the ring.
    Also, I had the same issue with the screw locations. I wonder if they make a longer screw. The one at 1 o'clock is set deeper on my valve (I think it was plumbed in crooked).
  7. Marlinman
    Dec 13, 2018
    For a longer screw Delta has a RP12630SS that is 4" long. Or you can pick one up at most hardware stores. The thread size is 10-24. Make certain the screw is stainless steel.
Similar Threads: Need help
Shower & Bathtub Forum & Blog American Standard Aquaseal, Need parts help--shower valve leaking Mar 22, 2021
Shower & Bathtub Forum & Blog Phister OX8, Need help with ID of shower faucet Mar 15, 2021
Shower & Bathtub Forum & Blog Need help to identify shower drain type Feb 22, 2021
Shower & Bathtub Forum & Blog Shower help needed! Feb 19, 2021
Shower & Bathtub Forum & Blog Help needed how to rebuild Am Standard B200 shower mixing valve Feb 19, 2021
