Mathieulemay3
I redo my basement bathroom and found this... lead won't be high enough for the new floor.
Top section is 4 inches wide and the bottom hole is less than 3 inches, probably 2 1/2 due to the lead that is inside.
Bottom of that is ABS so there is probably a seal around lead & abs.
Is it easy to remove without damaging the pipe? Should I seal the new pipe inside or outside?
If outside i may need to break concrete around the pipe, what the best way, drilling holes?
I don't have any plumber that can come before January and this is blocking me from finishing the floor.
Last time plumber came and left me a lead repair 3x4x3x12, but it doesn't fit at all in it.
