Hello. Looking for some professional advice. Live in Fayetteville NC. Built a two story garage a few years ago on a slab that is roughly 70 pipe feet away from my home. The garage sits lower then the home. I am working to finish off the upstairs for another living space. Upstairs is fully insulated, heated and cooled already. I need a pro's opinion on the best option to get the waste back to my house as I assume that would be the best solution over a septic or compost. I have already ran a 3/4 pex pipe 12" in ground for water along with a 2" PVC pipe for the waste when I ran all my wiring. The pipes are caped off in crawl space of my house and the 2" PVC is capped under the ground by the garage and pex was ran in a 3" insulated PVC pipe into the garage starting 12" below grade next to the garage foundation and elbows into the garage from the rear through the wall. Please ask more questions if needed to provide advice. Thank you so much!
