Stapleerp
I have a water tank that is currently being filled by a typical float valve with a ball on a stick. Due to another issue (that I won't get into) I need this to turn off instantly (or pretty close to instant) rather than gradually as the ball rises and gets closer and closer to closing it.
I would think something like a normally closed solenoid valve would work. With some sort of water level sensor that if it drops below that the valve would open and water would come in and then as soon as it hits the sensor it would stop.
I cannot seem to come up with a product that will do this. I see some float valves like you use in a sump pump hole but due to the nature of this tank I do not think something like that would work.
Does anyone have any experience with some simple all in one product that would do this? Valve/Sensor all together plug it in and go? Or are there other ways to get some sort of spring loaded mechanical float valve that will close quicker.
Thanks in advance!
Thanks in advance!
