Need advice with laundry room remodel
BradM
New jersey
I need a second bathroom in my house and want to put it in my laundry room/mud room. Is there any way to add bathroom plumbing into a slab floor that is loaded with a continuous radiant PEX heating loop, without destroying the entire slab and heating system on this level?
BradM
New jersey
Thanks. Wall where toilet would go backs to an unheated garage on slab. Where does waste get from wall to waste pipe from?
BradM
New jersey
I looked up some of the sani flos and i see they macerate and can go to the side, and take other plumbing, that will help situation (tho not sure where to plumb it to). More research, do you have experience with these, do they work, are there any that aren't crazy loud (per reviews), is saniflo best brand for this, is there a reliable model you can recommend, do the motors break often?. thank you.
ImOld
Octogenerian
In the rumble seat
I have and have installed a number of Saniflo systems. The toilet is bolted to the floor and requires two 1/2" holes drilled a couple inches deep. I can give you detailed info on anything Saniflo. But, your problem is you cannot safely do anything to the floor. Lots of things to overcome but can be done starting with a raised floor.
