Need advice on wet vent plumbing for bathroom changes
Monte435
florida
I am expanding an existing bathroom. The current bathroom has a wet vent (2") with a single sink, a shower and a Toilet. The new layout will have dual sinks, tub, shower, and toilet. I am moving the toilet location. Single story house on concrete slab. Located in Florida IPC code. Main line is 3". Lines to shower and tub are 2". The location I am moving the toilet to happens to run almost directly over the main horizontal drain line. I am wondering if I can tie this in with a Wye and a 45 directly up to the toilet? Will I have any issues with the toilet siphoning the tub or shower traps? Drawings attached
Monte435
florida
Also, since the WC is directly over the
horizontal line, I also need to know if this orientation of the WYE+1/8 is ok or if it will cause clogging issues. I get conflicting info from different online sources.
Monte435
florida
or do I need to use this type of orientation and move the toilet away from directly over top of the line
wwhitney
Berkeley, CA
Conventional wisdom is that the second picture is better. I believe the first picture is allowed. I don't know if there's a performance difference.
Cheers, Wayne
