Hi Terry!
I have a 2 storey house with existing full bath on second floor.
I'm installing a sink, toilet and washer/dryer on the main floor. (All close to each other) Existing washing machine in basement has a dedicated 2" vent leading up to the second floor. This could possibly be disconnected from the basement and used specifically for the new utilities.
Here's the tricky part. This vent runs up thru a load bearing wall and I have to tie the new lines into it. Can I do this without boring holes thru the load bearing studs? ie; tie into the vent via the basement, come over under the utilities and up thru the regular partition wall that the utilities sit against. I suppose gases could get trapped if I do this though.
Any ideas?
Thank you, Ross
Any ideas?
Thank you, Ross
