tmy23
Thanks in advance for any help...So ceiling tiles in the kitchen started coming down today with water. Directly above it is a bathroom. Didn't want to pull kitchen ceiling, so opened up the bedroom wall behind the shower valve. The leak was a loose upper compression fitting on adjustable connector which connects the tub/overflow drain to the trap. I'm not a plumber, but sort of shocked that the plumber put a compression fitting in an area with no access?
Anyway, am thinking of pulling it out and replacing with PVC. I can cut out and replace the trap, but I don't really want to mess with the tub drain/overflow. As you can see they glued a threaded fitting into the drain/overflow, can I glue use a female threaded fitting on the new trap piece and glue it to that threaded fitting? I didn't know if I would be able to work it tight before the glue seized up? Seems if I really glop the glue on I should be able to get enough turns?
Thoughts? Thank you all!!
