gregoryxlt
Hello,
Been reading here for a few days now to educate myself about my water well.
This mountain house where this well is has been vacant for nearly 5 years. I shut the water off each fall and drain the system so it doesn’t freeze.
Now I plan to rent this house, the water is slightly rust color so I drained the pressure tank 6 times today. With the drain still open after emptying I turn the pump on and would get a second or 2 of rust then water would clear up some. I would then close the drain and repeat.
After doing this I then go up to the house and let the water run for maybe 10 minuets but still see a slight brownish color I the toilet.
Question, what would be my next step to clear the water?
Also while running the water the pressure gauge will be at 35 psi then drop down to around 20 psi before the pump kicks on then back up to 35 again. Is this normal for a well? Or should the pressure maintain itself at 35?
I would like to increase the pressure to 50, how do I do that? I’ve attached a picture.
The 2 tall green tanks I would think I believe are the softener tanks? The tank on the right when I open it has a tube with holes, is this where I add the salt? If so how much? Also the 3/4 tube with the holes, mine is broke can anyone tell me where I could buy another tube?
Last question, my 1 inch brass T that goes into the pressure tank is cracked and leaking, where would I find one of these? I’ll add another picture of it.
My apologies for all the questions but I need to learn about this system if I’m renting this house.
Thank you for any help,
Greg
Greg
