Those type controllers are junk, and they are hard on pumps. That is why you can find so many different brands of that same gizmo, as they are made to make money for the pump company, not to last. And no they will not work at all on pumps of a larger size. The company will say you can plumb them in a bypass and use them with a large pump. But plumbed this way they are harder on large pumps than they are on small pumps, which isn;t good.
To help you with a GOOD pump control, we still need to know what size pump you have? 6 bar is like 87 PSI, which sounds a little high but probably what you need. I would get a pump that can make the pressure and volume needed, then control it with a CSV set for 87 PSI, and use about a 44 gallon pressure tank with a 80/100 pressure switch setting.
See this link after playing the following video.
https://cyclestopvalves.com/pages/municipal-one-pump-above-ground
