Navien Thermostat Connections
rcrboy
USA
I am installing a new Navien NHB-150H boiler. When I look at the wiring diagram it confuses me as to which terminals I should connect my two wire Honeywell FucusPRO TH5000 thermostat to. The boiler appears to have 4 thermostat connections and I used T/S 1 connection with the red and white terminals. But boiler does not fire, any advise? Thanks
If this is confusing you I suggest you how someone to help you. I would guess this isn't the only thing wrong with your install.
